RANCH HAND RNHGGC06HBL1 LEGEND GRILLE GUARD WITHOUT BODY CLADDING
The ranch hand legend grille guard is the original icon of the vehicle protection industry. providing outstanding protection for various 1/2 ton trucks the legend grille guard is one fully welded piece of steel mounted to your vehicle’s frame in four locations creating a solid barrier between your truck and unpredictable obstacles.
Features- 5/16” upright thickness add to toughness and durability
- Frame mounted in four locations to eliminate vibration and ensure the most secure fit
- Constructed from 12-gauge steel tubing; solid material amplifying strength and sturdiness
- One-piece welded designs with no expanded metal prevents rattling of multiple pieces
Compatibility- 2003-2007 Silverado 1500
- 2003-2006 Avalanche
Specifications- Dimension:31 H x 36 W x 85 D
- Weight:146 lbs
Price: 916.31
