BODY ARMOR JK2394 STEEL REAR BUMPER FOR JK JEEP WRANGLER - BLACK
Features- High clearance design is compact to the body to maximize departure angles.
- 5 millimeter steel plate for strength.
- Dual wheel bearing pivot system.
- Retain OEM hitch.
- The bumper is notched to retain the factory trailer hitch preserving the Jeep towing capability.
- 42 millimeter machined pivot shaft for the new swing arm 5293 or 5294.
- Reinforced gusseted mounting plates enhance the strength of the bumper.
- Fully welded dual shackles for recovery points.
- Easy bolt-on installation.
- Finish - Black.
- Model - Jeep JK.
Price: 574.33
